Yamaha CA-810 and CT-810 LED conversion
ymarko
Finally I got some time for long-awaited project of LED conversion of gorgeous Yamaha CA-810 and CT-810 couple.
I believe green is Yamaha (and Sansui) color.
Two CA-810 VU meters originally have 4 white incandescent lamps, and 2 were gone, so the rest 2 were very gloomy. I satisfied 100% with this conversion.
CT-810 is different. I feel like Yamaha cut corners in its lighting.
The tuner dial has no lamps whatsoever, thank you, Yamaha for being so cheap in otherwise great tuner. Most people listen music at night and non-illuminated dial scale looks very dark & gloomy to the point that the whole tuner doesn’t look attractive.
I had to address 3 issues:
a) VU meters.
Each VU meter originally has only 1 white incandescent lamp (very dim). And no room for more then 1 LED (unless I destroy originality, which I never do).
b) Dial pointer.
Dial pointer originally has 1 white incandescent lamp that goes through blue filter and the resulting color as rather gray and very gloomy, practically invisible on dark scale.
I replaced it with 3 red LEDs. Mixed with green dial, it creates yellow pointer that quite visible.
c) Dial scale.
Originally, no any lamps at all. Scary stuff.
I illuminated the whole large glass (not only scale portion). I did my best under the circumstances because Yamaha doesn’t provide enough voltage to work with. In reality CT-810 looks better then on these pictures.
Yamaha LED conversion
Clint & ymarko, excellent! Just excellent!
Wish I had those skills and ability to perform such a task. Y'alls tuners look kickass to say the least. Way to go and thanks for posting and sharing.:tresbon:
Guys, this looks great! I'm about to do the same for my CR-2020. May I ask where did you buy the LED's? Thanks!
Fantastic! I'd like to LED convert my CR collection as well... some details as to exactly how you did it would be great - source, how to hook them up etc.
w1jim hooked me up on my CA-2010/CT-1010 with the green led's as well. I thought it looked great, some people felt it should have been left original but I think the yamahas look really nice w/ the green.
another one I wish I hadn't sold but you can't keep them all.
as long as they can be returned to original I don't see the problem! LED conversions seem like they are non-destructive, so I say go for it!:thmbsp:
(and I plan to do just that to several of mine!)
a) VU meters.
b) Dial pointer.
c) Dial scale.
Good morning! Can you tell me where I can order these LED strips you used for your CT 810 and the size of the LED's. I can't seem to find them anywhere on the internet. Greatly appreciate your help! My email: mapayne70@gmail.com
Have a great day and appreciate your time!
Mike
