aural junkie
Hi all. New here and I need some help.
I finally got my hands on some vintage Yamaha gear, namely a CA-810 and a CT-810. The tuner is great but the amp has some problems.
Namely, output in both channels sounds terrible through my speakers. Specifically, it sounds like sound is coming from underwater, with the lows, mids and highs all off.
I don't think the issue is the pre-amp, as connecting the pre-amp out on the yamaha to my denon pma700ae produces incredible results. I mean music sounds freakin amazing in that set up.
I tested the DC output to the speaker pots on Yamaha before I bypassed it through the Denon and there doesn't seem to be a problem - 4.5mV on the left channel and 10.5mV on the right.
The volume pot is flawless (not scratchy) and the balance and treble pots are the same. The bass pot is a little scratchy but I know how to fix that with a bit of deoxit.
On close inspection, the board inside doesn't appear to have blown anything.
I've used the google but to no avail. Any ideas where I start?
Out of tolerance fusibles in the PS ? Bad solder connections on the pass transistors ? At least its easy to get to.Mate mbz has got your 6 .
