ukfan4sure!
Expert Smoke Releaser
Hey, I'm hoping someone will have the heart to give me a hand here. I recently (and finally) purchased a CA-810 that I've always wanted. Problem is, it's got a right channel out problem and I just wanted a little advice on how to figure this bugger out.
I've determined it's in the preamp. If I jumper in from another preamp, the main works fine. I had a suspicion it was the volume/balance knob as the balance is scratchy. Not sound scratchy, mechanically scratchy. I removed the 4-gang pot and it seems all of the potentiometers are doing their jobs. In measuring the center leg to each outside leg, I get expected resistances, and the expected resistance across each outside leg, the total R value of the pots. They are Balance: 5K, and Volume 200K.
So being of limited means (no O-scope), is there a way to find out where exactly I'm losing this signal? Can I use a multimeter to trace the analog through it on the right side? I'm going to tear it down and do a preliminary de-oxit, just in case I'm losing it through one of the switches.
Thanks!!
Thanks!!
