Yamaha CR-1020
ok to switch on the amplifier as it is in the photo.
Then just carefully touch only the output transistor with the red probe?
This will not be necessary if you can properly adjust the bias at the correct test points.
Which is 9-11 mv .. Target is 10mv.
Ok. I literally changed it the other day.
I'll check again, there's only one I think.
May have to stop shortly as it's late here but will get back to you.
Again, I appreciate your assistance on this.
Hi Avionic,
about to order a few items from Mouser and this item may well need a replacement.
Do you happen to know the ideal replacement?
On power supply board 1 its R725 and labelled IP 15
It’s the red one on the left and it’s twin is on the right hand side of the photo.
