Yamaha CR 2020 Power Switch Connection Diagram
ttspinner
Hello, Newbie post here from Canada. However, I've been gleaning a lot of good info for some time - thank you to all who contribute.
I recently bought a Yamaha cr 2020 that needed some TLC. Ok, the power on/off switch was missing. The receiver turns on when it's plugged, and off when unplugged....took it to my usual tech. He downloaded the schematics but the information on the power switch path was not detailed enough for him to work on it.
(the previous owner had removed the wires and disconnect the entire path to the power switch)
Can anyone help with a schematic or pictures on how to connect the power switch to the board - I'll pass this info on to my tech. Thank you in advance.
Welcome aboard spinner
Does your 2020 have a voltage selector switch on the rear panel ?
BR -- brown
WH -- white
BE -- Blue
GY -- gray
Thank you for the welcome....didn't look before handing it over to the tech, but I remember there were some instructions in French, so it's likely made for north America?
