Hello! I recently came into possession of a CR-2040 due to it being in the garage of a house we just bought. Having an (admittedly rusty) EE background I thought it might be a cool project to get back up and running. The behavior I'm seeing is that the unit seems to power up normally (you can hear the click of a relay after a second) but I'm not getting any sound on the right channel and very low volume on the left channel. This seems to be consistent for both A and B speaker outputs. Also, the left level meter does not move but the right meter behaves like one might expect when there's audio. I'm currently using the tuner as the audio input since I'm still scrounging for something that has RCA audio out. I've got the service manual and my next steps are going to be checking voltages on transistors. I wanted to check here though if anyone had any obvious first things to examine when working on one of these units.
From a quick inspection I would suspect the unit's been re-capped and there's a resistor mod of some sort on the tuner board. I don't see any obvious cold solder joints or shorts on the back of the PCB's.
Any guidance would be appreciated! Also, I'm not an audiophile so I apologize in advance if I ask some stupid questions.
Thanks,
Rick
Thanks,
Rick
