ecluser
I expect the final value to be close to 600 Ohms. For convenience, you can replace the 1.2k resistors by 750 Ohms and let the legs protrude under the board. It will be easy to shunt temporarily the 750 Ohms resistor by simply pinching with your finger another resistor, until you have the lowest offset. Then you cut the legs and you solder the shunt resistor under the board. For this you need a handful of values.
