ndstudio
Hey all,
Setup:
Yamaha CR-620
Yamaha YP-211
2x Legend Audio Speakers - 8ohm 100w Max
Yamaha YST-SW45 (Active Powered)
My Yamaha CR-620 Receiver started to overheat and I cant seem to figure out why... I first noticed a smell coming from my A/V setup about 4 months ago but it soon went away. I figured it was just some dust getting inside the vents of the receiver or something and causing the smell. Then last week I noticed the smell came back and soon realized the smell was coming from the CR-620. Turns out that there is a lot of heat coming out of the left side of the receiver where the transformer is located. I started to use an Infrared Thermometer (see attached) to track the heat and the unit would heat up immediately when I turn it on and would start to rise in temperature all the way to 160F... (obviously I would turn it off at this point).
Oddly enough, last night I wiggled the knobs, turned it on and off multiple times and rewired the speaker connections and the heat has dissipated to about 85F degrees which I left on for about 2 hours last night and again for 2 hours this morning and everything was fine.
So at this point I don't know whats going on... Part of me thinks that the wiring to the speakers could have been the issue? and another part of me thinks somethings up with the transformer. Nothings on top of the receiver preventing airflow and it is sitting on top of a long TV stand that I am using for my Hi-Fi setup. (see attached photo).
Can a [potential] loose connection to the speakers cause overheating? Any help on this would be greatly appreciated! I love this receiver and its the heart of my Entertainment / Hi-Fi system setup.
Setup:
Yamaha CR-620
Yamaha YP-211
