dspear99ca
I picked up this receiver a few years ago for next to nothing as it was sold as non-working. I recently re-discovered it while moving a few months ago and to investigate what is wrong with it.
The lights come on when I turn on the power switch, but there's no click from the protection relay. First thing I did was pull the outputs to see if that would help - couple of screws an no de-soldering - but alas, no change.
I checked voltages at the emitters of each driver transistor (total of 4 in both channels) and while it took awhile to stablize after power-up, they generally ended up somewhere between -1V and +1V, "in the zone", shouldn't be enough to trip the protection.
I checked the collector of TR809 which powers the relay, schematic notes it should be "0" and that's what I read. So... not sure what's going on. If there's no power to the relay (0V) then it ain't gonna' click. The schematic doesn't show the internal wiring of the relay, it just shows a rectangle with a connection to the collector of TR809, another connection to ground, and a diode around the relay from TR809 to ground. A dashed line indicates that the relay controls the connection from output stage to speakers. I've attached a photo of the protection circuit. Anybody have ideas as to what I should check next, or how this relay is supposed to close with 0V applied to it per the schematic?
like reading a Master at work.
