Yamaha CR 620 with loud hum.....
Look at pins L1,L2 , L3 and L4
L1 should have 3 wires attached
L2 has 2 wires
L3 has 2 wires
L4 has 3 wires attached..
The L (lamp) pins are close to the black cap in this photo.
index.php
The lamps look to bright in your photo. So they are likely the wrong size ..Voltage or current or both..
L2 has 2 wires
L3 has 2 wires
index.php
And you'll notice one pin is a "loner" and has no trace connected to it. It serves as a "junction" pin for 2 wires.
That was a 30 second exposure and iso 64, they look brighter than they are actually in real life. Here is another pic from the day before, a quick snap with my cell phone -
You've even got the rare plastic headphone hole plug! The bulbs may be messed up, don't know, but that unit is known for having lots of failing caps. IMO, it's a sweet sounding receiver if given a proper restoration.
Could be the replacement bulbs are too big for them too. It's not a big deal either way. I am just used to seeing the greenish tone.
I have the same unit and there is no greenish tone. Some are as his picture shows and some are green. The original lamps are not as strong as my pioneers with similar lamp colour.
I was told the greenish tone is a "sock" that goes over the lamps, again maybe I misheard what I was told: )
Not... They were all greenish.. Your green condom has dry rotted away.
You may be correct, mine are a yellowish white and several i have seen are like this. Maybe the green casing has rotted. Cannot remember if they were green 50 years ago lol
Its pretty common for those bulb filters to fade,dry rot or melt after 50 years..
