potch
Hello, picked this unit up today and pulled the cover off to have a look. There are 2 square tubes protruding up from the board. One is loose and the 2nd one is not. They both seem to have corrosion around them. The loose one is circled in red in the attached picture. What is the function of these components, is the corrosion an issue and is the loose one also an issue?
The receiver seems to work with the exception of the bulbs. Oddly enough, when I was trying the FM tuner, the bluetooth receiver, connected to the AUX port and streaming from my iphone, was bleeding the music over to the FM channel.
