Yamaha CR-640
EifX
Te Be or Not to be....where is my coffee!
Hi There, I have got on of these on the bench and my knowledge is not advanced enough to handle the behaviour of the amp.
When I first tested the amp with dummy-loads and signal generator en scoop. I just saw noise the pots and switches.
After cleaning the pot and switches I tested it again and after turning the balance from left to right the protection relay started to rattle of en on. I tried to set the dc-offset, but I could not resolve the behaviour. So I started trying to figure about where the problem might be.
First trail of thoughts: If the protection relay switches on and off then there should be "DC" and "NO DC" on the speaker output(s)....how do I measure that?
Second trail of thoughts: Maybe the protection circuit is failing to detect "DC" or "NO DC". I replaced 2 caps (c-901 and 902 in the protection circuit, and it looks like this was the issue. No rattle snake noises from the relay any more.
I started writing this post asking for help. But during writing I though let's just go for my gut feeling.
Just saying: "Better learning trying then always asking for help".
Keep you posted if this fix is permanent.
Monitor the DC offset at the TL and TR pins as per the service manual, verify that it's not ramping up/down. Spec is 5mV.
