MiKokomojoe
Hello fellow Yamaha AK members;
I am working on a cr-820 which has the "no output, lights up, no relay click" syndrome. I have gone through the older threads which were helpful in focusing me in on the right areas.
I have a TR721 transistor which reads 230 degrees when I point my thermometer gun at it, so I am going to order and replace that.
The other suspect is that one of my output transistors on the heat-sink side of the chassis ( the one nearest the front panel) reads ol and ol when I check the continuity of each pin against the back of the transistor. This one is labelled 2SB555. I need to be able to find the Mouser part number for this, but the mouser site is too overwhelming for me to get through it. I am thinking of just replacing all 4 of the output transistors while I am elbow-deep in this. The numbers on these, from left (Back corner-to front) are D424_2SB554_2SD425_2SB555.
I don't know why my transistors are marked differently from what I see posted on other threads; is there a difference between a 2SB557 and a 2SB555? This unit has been in the shop before for power issues. Maybe they went with a different part.
I am not any good with my DMM or terminology, so please don't throw a lot of numbers at me. I am good at buying and replacing parts. Thats just the way it is.
Thank you in advance for any assistance; I value the AK brain trust very much.
