ZanderTibell
Hey! I have a Yamaha CR-820 that I don’t get any sound from. The unit powers up fine and the lights and everything else seem to work but the amplifier section seems to be blown. No fuses have blown but the relay doesn’t click. The output transistors doesn’t seem to be shorted and all four reads about the same. I have little knowledge in the field, just a happy amateur that wants to learn. I have repaired a amplifier before but this problem seems more subtle. FYI I’m from Sweden so English isn’t my native language. I hope you could help me. I have measured almost all the transistors and drivers in the amplifier section and no one appears to be blown, also (what I believe is) the emitter resistors read fine (the four next to each other) and the resistors with ”socks” on them read fine (I think they are the fusible resistors). The 68 ohm resistors read perfectly. I can’t find the problem. When I measure the output transistors leg to ground I get a high voltage that I don’t know if it’s right. I put my negative lead to the negative speaker output and the positive to each leg and when I measure I get between 16 and 18 volts on the output transistors. On the output transistor casings I get ~43v. On the voltage regulator with the heatsink I measure 44,4 vdc between the heatsink and negative speaker terminal. On the big coils near transistor 722 I get 19 volts on one of them and 24 volts on the other. Between speaker negative and TP1 and TP2 I got 24v. I tried removing the output transistors and measuring them separately and then seem to be good and read about the same.
After leaving it on for about 45 minutes the transistors 719, 720, 721 and 722 get really warm. I know it’s normal but I can’t touch them without burning my fingers.
I have heard that a member called ”Avionic” is an expert on these and I hope I can get in touch with him. I would really appreciate input on this and I would be happy if you could dumb it down and make it like a lesson cause is want to learn more and I think that other people would appreciate a lecture too! Kind regards Zander Tibell
