As far as deoxiting the pure direct switch, I did what I have done on a few other switches now and drilled a 1mm hole on the end of the body so that I can insert the needle on my Deoxit spray tube and shoot stuff in there.
Actually the needle measures 0.90mm and the drill bit 1.1mm, the hole is just large enough to insert the needle, which efffectively seals the hole against back spray
I use a little pin vice to drill the hole, slowly while clearing the debris. With a little care it's possible to do it without leaving and plastic debris inside the switch.
The Deoxit gives a pressurized blast that comes out of the entire length of the switch. It got 5 blasts, with a lot of switch switching between eaxh one.
