MWH901
Hi, all... unit will not power up at all. IC1 (an NJM2041DD op amp for the CD input) was blown apart. I removed it from the board for starters, have not replaced it. Also R295 and R296 (per the schematic, 1-ohm flameproof resistors) looked a little crispy and measured ~5 ohms. I changed them for fresh 1-ohm resistors.
Checking voltages, starting with the transformer secondaries:
Orange 1: .153 V
Orange 2: .153 V
Red 1: 0V
Black: 0V
Red 2: 0V
Should I be getting something on these? In other words, is the transformer shot, or is this like one of those funky Yamaha 'X' power supplies where something upstream shuts down the transformer output if it's out of spec?
Thanks!!
Orange 1: .153 V
Orange 2: .153 V
Red 1: 0V
Black: 0V
Red 2: 0V
Thanks!!
