Yamaha EQ?
Zach S.
Member
Can anyone tell me if there was an equalizer made in 1979? I'm looking for my uncle for a good eq to pair with his 640. Can't seem to find any information on one from that era so I assume there wasn't on made with that line.
According to Orion, the first equalizer listed is from 1982. The GE-5 10 band, list of 245. sold from 82 to 85.
HTH
Kim
I'm thinking the same. It sounds so good without an eq. My uncle was hoping to be able to "fine tune" it though so I thought if I could find a Yamaha eq for him maybe that would present the best sound modification. Since there isn't one available from the same model year though I wonder if it will diminish the sound more than help it.
An EQ should be used to cut frequencies in a room that are too pronounced. A 1/3 octave EQ is best. In Live sound that is what we use to notch out problem frequencies in a room for both feedback and tone. For home use, cuts of 1-4 db probably will end up being what is needed for room nodes.
I own a beautiful looking and sounding Yamaha Natural Sound GE-40 EQ:yes:
Yamaha GE 40 Natural Sound 10 band stereo graphic Graphic Equalizer
10 (1 octave) bands per channel
continuously variable subsonic filter frequencies
1985/87
That's the same unit I was looking at for him. Thank you for your input on the subject!
It's a nice unit and can easily be bypassed/turned off at anytime:yes: I have mine coupled with a Yamaha M60/C60 combination. BUT it's only for show (I love the lights) At times I bypass it and if I need to "Tailor" the sound It's in play. I have also used it with my Yamaha Cr 840, Cr 1020.
There's always the old Pro-audio Yamaha Q2031 family...
Though the Mono Q1027 came out in '79
I know I'm resurrecting a zombie thread, but I have a Yamaha GE-60 - AFAIK identical to the GE-40 except it includes a spectrum analyzer display and has microphone/pink noise room analysis capability.
I use it exactly as noted above - to cut frequencies that are resonant or otherwise boosted by the acoustics of my room. I use an SPL meter and test tones to get everything relatively flat, and then leave it.
It's a high-quality unit, but I have to say, it's also a little bit of a drag because it definitely adds noise to the circuit when it's engaged. When it's in the chain but the EQ controls are on "Defeat," there's no increase in noise. But when I engage the EQ, I can hear an increase in noise with no signal playing and my ear about 6-12 inches from a speaker.
Without the EQ, though, the room produces a nasty bump from 4-8kHz (accompanied by a less-annoying dip at 16kHz). This makes everything harsh and unpleasant, so I have to keep the EQ in the circuit.
Makes me long for a high-quality, 32-bit or 48-bit pure-digital EQ, similar to the excellent volume control built into my Oppo BDP-105. The Oppo is so good that I've cut out my preamp entirely and use the Oppo as my control device. But it still has to go into the EQ, which then feeds the power amp. (Believe it or not, this produces a result slightly better - and no noisier - than feeding my preamp from the Oppo and keeping the EQ in the tape-monitor loop on the preamp.)
