Yamaha GT-2000L Cue Problem
Crazeehorse
I have had my Yamaha GT-2000L for about a month now and love it to death. Over the past week though I am having a cue issue where the tonearm will not lower all the time. It just sticks once in a while and will not lower until I apply some very light pressure on the base where it lowers. Once I do that it will work most of the evening as it should. Has anyone ever had an issue on a GT like this? It has the stock tonearm. I do see a screw on the cue base but I cannot find a service manual anywhere for this so I have not touched it. Maybe a some fluid needs freshened up? Thanks in advance.
Crazeehorse, that should be a relatively easy fix as I took my GT2000 tonearm off last night to clean it up and make it all mint like:).
First off remove the headshell, counter weight and anti skate wire and set aside. Then undo the tonearm cable clamp and disconnect wires from pre amp. Find the right size Hex/Allen Key and remove the two bolts holding down the tonearm to the base of the turntable. Once removed, gently lift the tonearm from the base and you will see another cable connected to the base of the tonearm. Using some needle nose pliers, gently pull the white wire connectors (molex??) apart. You have now released the entire tonearm assembly.
If you now look at the underside of the tonearm base you will see the plunger mechanism that controls the part that the tonearm rests on when cueing. If you add a couple of drops of high quality oil (silicone oil???) and work that plunger for about 20 seconds I am sure it will fix your problems.
I wish you had posted this last night as I would have taken pictures for you. Rest assured it is an easy fix.
Ateal,
Thank you very much! I was looking at some pictures online and was thinking it wasn't too bad to fix. I agree I should be able to fix this pretty easy. Thanks for the tips.
