AstarOfDavid
I've taken the entire unit apart (aside from the detaching the heatsink) as I wanted to look the boards over under a magnifying lens for broken or loose solder joints. Which I found none. Then I had a look around at all the capacitors (as I have worked on many TV's stereos computer motherboards that have had bad caps) so I know how easily it can be for a cap to be out of spec and cause the device to not work or power on/off etc. However after close inspection I can't see any caps looking bad in any way no budging no leaking and none are loose soldered. But now that I know the location to look - I will be going over this area much closer when I do tests. Also when I go into diagnostics which buttons do I need to press to get to the screen you are asking about?Thinking you would be wrong in your assumption.
From the service manual, shows +/-5,12V regulators
Exactly what was the diagnostic message, ie PS PRT nnn
A voltage of 94-95% unlikely to be regulator failure, more likely to be a leaky cap, maybe post a pic of that board highlighted above, showing caps. I'd be surprised if 95% voltage would trigger protection, considering mains AC drift.
