Hello, a new member here!
I have a Yamaha KX-W421 dual well, cassette player/recorder. It's approximately 18-20 years old, with "low mileage". I'm the original owner. Given it's age, I thought it would be a good idea to replace the drive belts, so I ordered replacements, and I, through some research, found a picture of the insides of this unit, on a site that I have since forgotten. Based on the picture, I thought it would be a fairly easy task, as it appeared that the belts were "out in the open", compared to some of the other cassette drive mechanisms that I saw in various videos that I came across.
However, I was only partially correct. After receiving the new belts, I wrestled the deck out of my entertainment center, and proceeded to remove the outer cover. Initially, I was quite happy, as the belts are indeed very visible. HOWEVER, after slipping the belt off the large pulley (capstan?) it appeared that the belt was "trapped" in position by a "support leg" of the drive motor. I assume, unless I completely overlooked something, that getting the belt around this leg will require extensive disassembly of the unit.
Do any members here, have any experience with this deck, and could enlighten me as to what has to be done, to remove/replace the belts? I was able to download a "service manual", but as others have mentioned, with respect to these manuals, they provide a lot of technical data, but very little on the steps required to make repairs and/or perform maintenance.
I'll appreciate any information that can be provided.
