Yamaha M-80 Help Needed...Again
Good Afternoon,
I started a thread a while back requesting assistance with a bit of a wild child M-80. I was rummaging through old threads and it must have been inadvertently deleted in the shuffle. To re-summarize I got the amp with a couple of shorted outputs (TR133 and TR135). These were replaced along with the visually obvious collateral damage. Since then I have gone through quite a few cycles of identifying faulty/suspect components, replacing them, crossing fingers, and powering on.
I believe I left off with the discovery of a couple open emitter resistors (R153 and R157). They were replaced...powered on, still unhappy. A little probing with the meter took me to a shorted TR111. It was replaced...powered on, still unhappy. Here is where it gets interesting, at least to me it is interesting. I am powering up through a 200w bulb/dbt. The dbt bulb is blinding on power on and the red display on the yam has only a faint glow if any. However, when attempting to take further voltage readings I found that when I touched the + lead (- on chassis) to various components (on the left ch only) the dbt bulb goes dim and the yam display improves. The machine seems to be in protect when the bulb is lit, but when i get the bulb to dim it comes out of protect. Also, when the bulb is lit I do not seem to get near the 70ish volts where I should per the SM on either channel, more like 20ish.
At initial power on with dbt bulb bright I get:
+/-HB = +20vdc / -20vdc
+/-LB = +10vdc / -10vdc
After bulb goes dim
+/-HB = +74vdc / -74vdc
+/-LB = +37vdc / -37vdc
This seems silly, but below are a few places i noted that when probed the bulb dims and conditions "stabilize".
TR111 Collector
TR113 Collector
TR115 E&C
D113 Cathode
D111 Cathode
C125 + and -
VR103 (currently fully CCW)
I have replaced the following:
TR133
TR135
TR125
TR124
TR123
TR119
TR118
TR117
TR113
TR111
TR101 (replaced with 2x 2SK170; this had been done by someone else prior on the right channel)
R123
R125
R135
R136
R138
R137
R141
R143
R147
R151
R152
R153
R155
R157
R159
R173
R221
R222
R229
R231
R233
D103
D107
D109
D111
D113
D115
D117
D119
D121
D131
I'm not sure what to make of this other than something is killing my power supply on power up, it seems that the root cause may exist on the left ch, and that probing certain components on this channel seems to stabilize things a bit.
As always any help is greatly appreciated.
Thank you for your time.
Try a 100w bulb.
Same results w 100 watt bulb.
How many of the caps have you replaced ?
I replaced C131, C132, C125, C126, and C164 (47uf/25v bp). The machine appears to have been almost completely recap’d at some point. The 4 large power supply caps are original, as well as those on the pcb that runs the top right ch heat sink. What are the high mounted pcb’s referred to as…switching, xps, slims?
Thank you for hanging in there w me.
Measure the resistance of R221 and R222 in circuit will be sufficient.
What µf & voltage do you have install in the C162 and C163 position. Should be 1000µf @ 100 vdc..
C162 and C163 are 1000uf / 160v, not the original nichicons.
R221 and R222 measure 22ohms. I know these are included on my list of replaced components, but it is worth mentioning that just because they have been replaced does not mean that they have survived additional testing. Several components have been replaced only to go up in smoke.
I attached a pic, not sure how useful it is but never know.
I placed an order for a bunch of stuff. Typically not a fan of spray and pray, but I am not sure what else to do here. I'm all ears.
Is there a general assumption as to what may be causing this phenomenon? For example, since probing components with a meter whose negative lead is clipped to chassis ground seems to provide some relief, does that mean that the most probable root cause is an inadequate “connection” to ground or neutral or both? Has anyone experienced similar behavior or been made aware of anything such? I have little faith that the parts on order will clear up the issue, but not sure where to turn.
It may be worth mentioning that this amp was tossed in a dumpster, quite literally. It landed on its feet, and shows no visible damage except a slightly dented rear corner. I have not removed the front or rear panels to inspect. Starting to think it may be worthwhile to do so, but i really think it somehow just survived the plunge.
A digital volt meter has a very high input impedance, 1MΩ or greater. My usual thinking with this kind of occurrence is that there is an open trace somewhere OR that the capacitance of the probe is killing an oscillation. The meter adds a very small load to the circuit. Do you have an o'scope?
I do. As far as open traces go some of the pads, especially those at TR117, had experienced a heavy hand and were essentially nonexistent. I had to resort to jumpers, but have done my best to keep things going where they should, while touching nothing they shouldnt.
Not sure if i mentioned this but when i remove my meter lead the amp does not go back into the pissed off bright bulb state. It remains relatively calm. If i power it off and back on within a fairly short time it still remains calm. Only if i give it a decent delay between off/on does it go back to raising heck. Seems an open trace would be more likely to present itself in an all or nothing fashion (ie removing the lead would recreate the issue), but im no expert. I’ll poke w the scope.
That 'explanation', in my mind, decreases the likelihood of an open trace and increases the likelihood of a bad component and oscillation. A circuit on the edge of oscillation can behave very erratically.
