Yamaha M-80 Transistor location tr119 and tr125
Ftlbs
I'm working on an M-80 and believe TR119 and TR 125 are bad. I can't seem to find the location of them. I see them schematically but not in parts list nor on the main board which is what it looks like on the schematic. Any help is greatly appreciated!
They are located between the power transistors, against the heatsink. See the images in the service manual. If you don't have that, go to hifiengine.com or take a look here in the manuals section (which may have it - I didn't look, having a local copy already).
Thanks. I found TR119 listed as item 73 on the mechanism parts list. TR125 is supposed to be item 74 which I don't see anywhere. There are two smaller transistors per side that are on the heat sink at the X power supplies. Is 125 one of those?
They are both located on the upper, narrow , APS power supply board for the left channel. They would be the only two TO-220 transistors mounted to the large heatsinks topside. One is black and one is green if there still the OEM Toshiba's.
