Yes it should. Meters may be misadjusted.should the meter on the unit be going up to at least near full?
I played a 1 khz test tone on full volume and meassured the voltage.... the amp speakers meter was on 4 ohms and it read about 7watts, and the voltage output was around 6 volts. My calculations show that 6 volts should be 9 watts ish at 4 ohms. Even if the meters are off a little bit, it still was only putting out 7 watts!! now i will say, it was getting louder when i played music compared to the test tone, but still, something does not seem correct.
Not unless you want to unsolder the 6 transistors fastened to the large heatsinks on each board.should I unscrew the board and look at other side?
AC or DC ?You should be measuring AC voltage. If AC, your Tanberg needs to be looked at..83V.
