Hey all, first post here.
I recently picked up a Yamaha M4 amp on Facebook. When we tested it it sounded good (BA A200 speakers) but had dirty pots. I have since cleaned the pots with deoxit and they turn smoothly. When I plugged everything in the right channel (speaker A) would go in and out and also sound scratchy at times (no knobs turned). After a while I decided to try speaker B to see if I had any luck. To my surprise it worked just fine, but after a few hours I would get the same issue. Now the relay doesn’t click when I enable speaker B, but still does on A. Speaker A still has the same aforementioned issues with the right channel. I checked the relays and they were clean, however, I destroyed one in the process (loosened the spring). I do have a digital multimeter and soldering iron so was wondering where to start with troubleshooting. Thanks, Bootcoot.
