Hi,
I got this amp recently, nice cosmetics, but protection light is on.
R349 / R350 resistors ( 5watt or something like this) get very hot when the amp is on. I did measure some voltages off wires coming from the top board (RE, LE, RO, LO, E, MU) and the voltages slowly decrease to practically almost 0 from the time of turn ON, but I didn't keep the amp ON for very long.
I went straight for checking output transistors with VOM and they all check out good, 470 - 590 ohm range B -> C / E (NPN / PNP accordingly).
I am kinda puzzled right on how to proceed next. I only soldered out the otputs, and if they are good, is there any sense to continue checking other transistors on those two boards? Or what to look at next. All fuses are good. I did tap on relays, but no change. Front meter lights up but shows 8888.8 or something like this.
If anyone has been fixing "stuck-in-protection" problems (but good outputs), please advise on what to do next. Thanks.
