Yamaha mx1000u speaker issues
Muddywater31
Hey y'all!
First time posting so I apologize for any errors. I recently found a complete set of Yamaha equipment at Goodwill and it’s all in pristine condition. I am using an MX1000u amp with a CX1000u preamp. My speakers are old Polk Audios that I’ve had forever. Now the issue: I am only getting sound from my left speaker. It’s a random issue though and I replaced the speaker wire but no luck. I also ran the wire into speaker B rather than A but it is still the same issue.
Any tips or suggestions? I love this setup and I will do whatever it takes to get it 100%
Dunno about that model, but some of the Yamahas have problem of cold solder joints where the jacks connect to the board. My C-80 did. Previous owner brought the M-80 amp to the shop several times to try to figure out the intermittent channel. Problem is, the problem never was the amp; was a cracked cold solder joint for one of the C-80 pre out jacks.
Dunno if that's the case here but FYI/FWIW.
Do you have something that you can run straight to the MX and by-pass the CX ?
If you could come up with either a separate pre-amp or power amp. We could start eliminating possibilities.
I don’t unfortunately. It’s the only preamp that I have currently. I may be able to borrow one and check.
You could use a phone or anything with a volume control and a cable to feed it into the amp.
Frankly, since the amp has level controls, you could connect a tuner or CD player or whatever directly to the amp and use the level controls on the amp for adjusting the volume.
Wow I never knew that. I’ll try it with something here
I have a couple CX's on the bench as we speak. 1000 and a 2000.
2000 is a 1000 in a pretty dress.:D
Alright, it’s not the MX. it’s the CX
I found the issue. It was the cable running from the out ports. I wiggled it and the other speaker came on. Thanks y’all. Glad it wasn’t anything serious!
Hopefully its just the cable and not a cracked solder connection on the RCA jack. With tight fitting interconnect cables its very easy to fork up RCA jacks.
Damn @Muddywater31, that is a hell of a find, especially at GW! Just curious about the price and location if I may? Either way, I'm glad you scored and figured out your problem. Enjoy! :rockon:
Yeah, no kidding! This reads like those posts back before GW started Shopgoodwill.com. I can't believe those made it to the floor. Just WOW! :thumbsup:
