Yamaha NS-66
Google says Roman said:
The NS-066 were from 1982 to 1984 in the Yamaha range and were then the smallest model in the Yamaha range. Tweeter: Dome 3cm Woofer: 18cm from spruce wood cellulose Frequency response 55-20000 Hz Weight 5 lbs per piece musical power 80 watt level 87 dB/1W/1m Impedance 6 ohms Regards Roman
Must be a different speaker. These ones have either a 10 or 12 inch woofer and are 8 ohms. They are made in Canada and do not have a "0" preceding the 66. The model is NS-66, not NS-066. Could it be they were quite limited in quantity for the Canadian market, or did Yamaha mess around with its model numbers (ie, different model #s for the same product) as per its current practice?
