Yamaha P2100 score! Pictures!
Hi All,
Trying to hook one of these up. Can someone explain to me why there are two 1/4 inch jacks per channel under XLR jacks? I am trying to connect this to a Presonus Central Station and it only has one 1/4 inch out per channel.
Confused.
Thanks!
-brett
Brettra2@yahoo.com
The two 1/4" jacks are wired in parallel for each channel. So you can plug your preamp/mixer output into one, and then use a short 1/4-1/4 cable to daisy chain to another amp (presumably underneath in the same rack) so you don't have to run another separate cable from source to amp. Makes it easy to run an entire bank of amps that way.
