I'm doing a bit of work on my P2201 (updating fuse resistors and maybe the filter caps).
This amp has always had a quick, sharp pop thru the speakers at power on, so I am thinking about replacing the snubbers on the power switch while I'm at it. The current snubbers are an integrated capacitor and resistor package (.033uf and 120ohm, 250V).
I have some 330V .033 X-rated caps and 120ohm resistors on hand, but wanted to confirm how they would be wired. I've seen differing diagrams for how a snubber is constructed. Also, this switch is a bit different from the few others I've worked on.
It might be prudent at this point to ask if replacing the snubbers has a decent potential for eliminating or reducing the pop?
Assuming there is, I'll go ahead and replace them once I'm sure about wiring them.
Here is a pic of the switch as is. The purple wire comes from mains power, and is jumped across the switch. The brown wires go to the transformer. The snubbers are attached on each side of the switch.
My working assumption is that I would simply remove them, wire the new caps in their place, and then wire the resistors in parallel with the caps. If this is correct, I'll probably just solder the resistors across the caps, and then solder the caps to the switch, same as the integrated snubber packages.
I sure would appreciate a yay or nay, and any other guidance you might share. Thanks in advance.
