DWJames
I know this is in reply to an ancient post but I must share my troubleshooting tale since it might help you.
After deciding to find another PC2002M to get my basket case unit going I resoldered every joint on the DA and PDA boards (Ch1) only to have extremely low gain and distorted output if I cranked it. The output transistors were all new and the other channel worked flawlessly with enough power to bring my test speakers to their knees. The problem sounded EXACTLY as you describe.
What was the culprit? It was the bias protection circuit. Specifically the 2sc2320/2sa999 transistors were extremely leaky but not quite shorted. The three 390 ohm fusistors were also bad (replace them with 1/4 carbon film according to AK Yammie-master Avionic). Just for good measure I also replaced the 1uf 50v cap in the same circuit but it was definitely the fusistors/transistors on my unit.
I suspect there may be a way to disable the bias protection circuit but given the insanely low cost of the two transistors ($1 American) it would be silly to do so.
Just as an aside, while its really great to hit up AK and find somebody who fixed the same model with the same symptoms as the one you own, that doesn't mean you should blindly shotgun various fixes without any evidence. When you start using you noggin to fix gear then you can help others fix theirs and that's what makes AK such a great place.
Excellent, thanks for posting this :thmbsp:
I'm currently having issues with my PC2002M amp on 1 channel and I wonder if I'm having the same kind of issue?
On my amp, if I've been listening quietly for a while, one of my channels jumps up to roughly 10-15db more than the other and sounds kinda agressive and peaky. If you turn it up, that channel sounds overdriven and goes distorted and horrid, but doesn't light the 'clip' light on the front.
I can usually get it back to normal by turning it up a bit and letting it sort of register that it's bad, after which it'll just drop back to where it should be, but my speakers won't be thanking me for cranking up horrid sounds and that method of resetting things seems to be becoming less effective as times goes on.
Voltages are where they should be,
I'm getting +80.1v -79.9v on the 80v supply
Idling current of 10.9 and 11.1mv
DC offset of 0.5mv and 1mv
Do you reckon this could be the bias circuit?
Is there anything I can test/measure/check to find out?
I've tried a couple of preamps, just to be sure, but symptoms are the same
cheers,
James
