I was making great progress with the recapping of my PX-3, everything went very smoothly and the caps that were no longer available were replaced with equivalents and all polarities were closely observed, checked, re-checked after which all the solder joints were checked again as well by touching them up just enough to get the solder to melt and harden again. I had help from a great tech at Mouser in finding appropriate substitutes for the caps and all but a few were identical in specs. The couple that weren't were the same in mF but a bit higher in voltage, which I have read and was told that would be OK.
So, when I closed the table up I was surprised that I got NOTHING when I touched the 30 button, aside from the light coming on. The same went for all the other buttons, lights came on, but no movement. The fast forward and reverse functions are gone now too. Previous to the recap, I had only the 30 button NOT WORKING and the arm would not lift when at the end of the record. Now none of that works. I can get the platter to spin if I physically move the arm towards the record and while it spins, I have no way to drop the tonearm down nor does it then respond to any of the buttons. I can stop the platter spinning by physically moving the tonearm back to the rest position. I inspected the photo interrupters and they are all shining quite brightly, adjusted the position of those and still.....nothing.
I'm hoping someone can give me some suggestions as to how to "awaken" the thing......is there a "reset" button somewhere that I don't know about? I'm at wits end after working on this all day so I'm going to go to sleep and hope the answer comes in a dream or that someone here can enlighten me. I took pictures of everything when disassembling the table so am sure I got all the cables on there right again. They basically only go one way, so not much to screw up on there. I'm so bummed! Hope someone has some ideas......thanks in advance amigos.
One step at a time and I trust it will get resolved. I've had several components that were fixed with the help of those here who know about these things so I'm hopeful.
