Brian Henkel
I have a Yamaha PX-3 that seems to work for all but advancing the arm toward the center of the record. I took apart the tonearm transport and removed and cleaned all of the belts. I also took every switch apart and cleaned them with contact cleaner. They slide beautifully. It powers on, the speed switch works, the cut switch works, the move right switch works, The 17 and 30 auto play switches light when depressed. The repeat switch does not light up and the advance button does nothing. If I move the arm manually toward the center of the record the platter starts. If I press the down button it will play but the arm never advances. The motor is never activated to move the arm. Any ideas?
