Yamaha RX 360 - dead -
fireflimoon
Hi,
My wife and I bought a Yamaha system over twenty years ago that we have used a lot. Unfortunately, we may have killed the RX 360 receiver (200 watts) by overheating it - putting it in a tv cabinet while powered on.
When I power it on now I only hear one click. The display window hasn't worked for over a year so I am not sure if it is powering up but it appears quite dead. It won't play from the stereo or cd player.
Can something be done? If not, are there any suggestions for a suitable receiver replacement - should I try and get a used receiver if this one is dead.
Would you have any suggestions - it wouldn't have to be a Yamaha if that is ok. The speakers are Mission 761i (25-100w/ch 8 ohm).
Thanks
That was a combination I sold a lot of, entry level Yamaha receiver (RX-300/330/360) with little Mission 70/761/761i. Very nice.
I would not put a lot of time or money into that Yamaha. It was a nice budget model, and actually about 35 watts per channel, but if you have to resort to a professional for repairs the cost of the estimate would probably by you a suitable used replacement.
It is worth opening it up and seeing if a fuse has blown somewhere. It is definitely worth the few cents to replace that.
As for replacements, pretty much any good quality receiver will do. You can probably find something on Craigslist, Kijiji or similar locally. H/Ks and NADs sounded very nice with the Missions though another Yamaha or a Denon would do very well also.
Try simply replacing the bad bulb in the front display...Here is why...
A few months ago, I received a supposedly 100% working RX-360 from Ebay, only to find it to be D.O.A. upon arrival. Didn't have a schematic, but I do have a good electronics background. Display wouldn't light up, nor would the speaker delay relay (protection relay) kick in to enable to output amp. But I could hear a relay click in immediately upon power-up, however. So I removed the cover, and discovered that this Yamaha series has two separate relays. One relay, for the front display bulb, and one for the output amp. I stripped back the delicate power wires going to the front display bulb, in order so that I could measure the supply voltage going to the bulb, so that I could determine a suitable replacement bulb. I measured around 13 VAC, but while the multimeter 'load' was across the bulb supply voltage/front relay, this ALSO ALLOWED the speaker delay relay in the back of the unit to engage a few seconds later, so much to my surprise, all of the sudden music was blasting out of both the left and right speakers, and I had a 100% working receiver again (well, once I replaced the bulb). Note that when I removed the multimeter from the bulb circuit, the unit would not fully turn on again. Only the front relay would engage, but the rear relay stayed off. (Exactly what you described above. i.e. You only hear the one relay clicking in right now and you have no display.) So, in my situation, a burned out/broken bulb filament was making the entire receiver appear to be stone dead.
So, check to see if you just have a bad bulb in the front of the display. Also, I am highly skeptical that your tv cabinet enclosure was capable of 'cooking' your stereo. These Yamaha RX-360's are pretty tough little units. Plus, they only put 45watts rms driving an 8 ohm speaker load (plenty of room filling sound for my requirements, though), so there is some power/heat dissipation, but they don't require alot of 'breathing room'. But since you said the display was dead, and yet you were hearing the one relay click in right away (that's a very good sign), I think you may just need a new bulb. Worth checking out. Let us know what you find.
I believe the original spec called for a 12 volt 120ma bulb. Note: Yamaha doesn't have any replacement bulbs anymore, but it is not mission-critical, so you have to substitute something similar.
I believe that I substituted a 14 volt 80ma bulb. My display was still plenty bright (unless the display was put in very strong, direct sunlight), and I was able to get 5 bulbs for about $6 including shipping right on Ebay, in the event that they burn out too quickly. So far, my front display has been running fine since last March on the same bulb.
Note that the bulbs are shaped like the mini-Christmas tree light bulbs, and you will need to solder in the replacement bulb, as it is hard-wired in place, OR twist the fine wires together and isolate them with electrical tape so they don't short out to anything.
Hope all this helps you out.
Side note, for heat-related issues...
I got one of these the other day at Big Lots for $7. It runs off 5V USB, and whaddaya know, they sell AC USB adaptors on the same aisle!
I plugged it into one of the sockets on the back of my RX-V995, so every time I turn the amp on, the fan turns on as well. I'm gonna go back and pick up a few more for other amps, for preventative heat dissipation.
