Yamaha Silverface selector switches
MonkeyRelish
I see lots of threads where one channel is missing, or sound dropping out.
The usual recommendation is to clean the selector or coupling switches.
These are all slide switches, and are hard to get De-oxit inside.
Even if you can get some inside, there is no guarantee it will work.
I purchased a CA-600 cheap which was listed as working fine through the tape input,
but nothing through the Aux or Phono inputs.
I was pretty that the problem was the function switch.
The photo’s below show what is required to clean these contacts.
FE1EDB53-D673-443E-90E2-7C5740B0DA3B.jpeg04A8909F-C591-4A83-B716-291DA7456404.jpeg78CE3BD1-50EA-42AA-A192-2E44604D8A0D.jpegA0ED7EBE-EBD0-479A-9B51-0EEE18BF6F76.jpeg4EB05AFA-32FC-4DAE-9A66-48F6FC7B7871.jpegD68AA884-54D3-4D01-ABA0-0DD0F48877D6.jpegD27CAC3E-B2C7-409C-8268-8A3248A93BF2.jpeg
In this case, the tarnished contacts weren’t the whole issue, the plastic cog was mashed underneath.
Flipping the cog over, a bit of creative modding to make it work, and works like a bought one.
Hopefully you cleaned all that oily deox-it over spray off the board before you reinstalled.;)
index.php
Yes I did. The previous owner’s “tech” had tried the De-oxit fix to no avail.
Looks like he gave it a bath.
I only used a bit of De-oxit on the cleaned contacts to help stop future tarnishing.
Mr Relish
Hello
What is the part number on it ?
KA50021.....?
KA50027 45 going by my photos, but I can’t tell if there is a number between the 27 and 45.
Doesn’t look like it. The board is reinstalled, and the amp buttoned up.
I’ll check when I replace all the electrolytics. Waiting on Digikey ATM.
Mr Relish
View attachment 1960310View attachment 1960311View attachment 1960312View attachment 1960313View attachment 1960314View attachment 1960315View attachment 1960316
Did you also cleaned the black pins before you popped the sliders back into the board?
