longgun708
Member
I have a T-85 that has no sound output. It lights up and lets me get AM and FM channels and keeps the channels indicated after powering down. I have tested in circuit all of the transistors and don't see any that seem suspect. I also checked the capacitors ( with a fluke 187 esr) and all seem to have reasonable values. I also checked the power supply and it seems OK too. I am working with a schematic that I got from hi fi engine and its a little cloudy at times but works ok. I have read and reread the posts on here that covered this topic and I didn't see anything that seemed similar to the issue that I am up against. I do not have a scope or a signal generator. Just the Fluke.
I did find a lower than indicated voltage on Q 263 by 6 volts but can't see a reason why.
Can anyone offer any insight? I would appreciate any help. The other posts that I read seemed to find a bad capacitor but all of the values seemed reasonable. What would a bad cap reading look like?
I like doing this and am just trying to get it working again but I am an admitted beginner.
Thank you
Thank you
