Yamaha TC-520 - Replace stop/eject button
wavey
I bought a discounted Yamaha TC-520 cassette deck from Ebay. It has a bent Stop/Eject button.
Can this button be detached independently and replaced? Appreciate any leads you can steer me to.
Follow up question: Unit outputs a pulsating overdriven noise unless I hold down the REC MUTE button. Sounds normal with REC MUTE depressed. Diagnosis?
Welcome aboard wavey..Probably get more assistance in the Tape Forum..
I would remove the faceplate to see better. If the button is plastic-chances are there is a metal lever that it's attached to. The exterior of the 'button' looks fine. Perhaps just a firm bending in the opposite direction might be a solution-get the faceplate off any you will have a better idea of what's feasible.
Hi Wavey, I have the exact same unit (TC-520) and it has the exact same problem. It sounds horrible unless you press the "rec mute" button. Did you ever find a solution?
