Hifibythekg
When disassembling these to thoroughly clean them.. can one remove the circular contact that sits on the black plastic centre piece with twelve studs?
Is it ok to bend up the copper contacts to remove everything for cleaning and then bend them back afterwards for retensioning?
Or should a more conservative approach be adopted and just clean as best one can while leaving the elements in place? Less risk of breaking or being unable to realign everything but... maybe not as thorough a cleaning as needed in order to get the best possible contact and signal?
The offending phenolic wafer switch is already removed - advice and comments gratefully accepted.
