willyrover
A while ago I picked up a Yamaha YP-511 with no headshell. After getting it all cleaned up and working properly, I ordered this inexpensive headshell to mount an Ortofon OM10 that I already had.
Now the problem was that I could get no where near the required 17mm overhang even with the cartridge mounted all the way back in the headshell. There was still a good 5mm or so too much overhang. The only way to align the cartridge was to skew it in the headshell.
To get the 17mm overhang, mounting distance needs to be around 32-33mm.
Next I bought this headshell. The listing said mounting distance was 32mm-41mm. Perfect! Except when it arrived, mounting distance measured 37mm -50mm
so it's going back.
So what is the deal with this table/arm? It seems like most headshells are too long for it!
So now, as I should have done in the first place, I'm looking to track down an original headshell. Problem is the manual and the service manual are vague as to what headshell it actually shipped with. The pictures in the manual show a headshell that LOOKS like this HS-800.
It is listed as being used on the YP-211 but again, information about the YP-511 is vague. Can anyone confirm that this is the correct headshell for a YP-511 and most importantly, the range of mounting distance allowed by the slots?
