I just got it set up last night and it is perfect.
I do not have the space for it to use the dust
cover which is in very good condition, so it
got packed away. I'll just keep the tonearm
covered with a cloth until I want to use it.
I didn't get the main box, but I do have the
styrofoam boxes for the tonearm and the
maintenance kit.
I don't know what the maintenance kit originally included, but I got the record cleaner which could use new felt,
a Yamaha screw driver, which I assume was
for the transport screws,
some tweezers which were handy for changing the cartridge,
a 45 adapter that doubles as an overhang guage,
and a tube of some kind of cleaner/polish
for the tonearm and platter.
I thought that the headshell was too long,
which made aliging the cartridge more
challenging than it needed to be and it seems
Yamaha knew this too because I found out later that there was a dot on the side of the headshell to line the diamond up with.
Overall, not a big deal.
I also got a sub weight that screws into the back of the counter weight, so it seems that this tonearm can use a wide variety of cartridges without concern of their weight.
I didn't like the flathead slotted grub screw in the anti-skate weight. The weight takes quite a bit of precision to set correctly, so tightening and loosening the screw to check the skating is cumbersome. I might try to find a torx grub screw that will fit, but I don't foresee changing cartridges any time soon, so it can wait.
