Will do! I live right by Sweetwater so I can run over there and get a amp pretty easy I think! I'll report back. As I am sure I'll find some issues once I hear it lolYa I would wait till you get a receiver or amp and preamp
Thanks for getting back with me! Yes, it does play all the way through and rehomes as it should. It just won't start playing from the start button.Have you tried just lifting the tonearm manually and setting it on the record.. does it play all the way to the end?? Does tonearm return home automatically??
Additionally, if it's in the middle and I hit the cut button, it returns as well.Have you tried just lifting the tonearm manually and setting it on the record.. does it play all the way to the end?? Does tonearm return home automatically??
Unfortunately, that screw didn't seem to change anything... HmmYes set down location of the tonearm on the record.. let me look around. Ginn a sec
That's kinda what I was thinking happened. Keep me posted. I think my motor mounts are fine. Everything is quite and the app I have on my phone shows the rpms dead on! As mentioned above, when I dialed back the counter weight to 1.75g instead of 2g it was just enough to allow the arm to pick up and move over to the record. Set it back to 2g and it didn't work. I guess I just have a chonky cartridge. It is all metal (weighs 8g) fwiw.I believe this is the correct adjustment screw for the set-down location. I had tweaked it at some point and found that it was now setting down a couple seconds into the first song instead of the run-in groove (need to adjust it back).
It sounds like the Cut button works if it will return the tone arm from a song in the middle of the disc and it also functions correctly if it returns after the last track on the side.
Does your Repeat function work correctly? Mine is set to Off but still operates — it was inactive until I used either the Cut or Cue button, so I must have something out of order.
I think there is a proper starting position for all of the clockwork features and buttons and it is easy to get it wrong when you’re rotating the spindle for replacing a belt or doing other service work, but I haven’t been able figure it out. I’ll be attempting to fix the motor suspension on my table soon, I’ll take another poke at the issue then.
It will like lift up to an acceptable height and then won't hardly budge toward the record. But when I dial down the weight slightly it's light enough to push over there. It's odd. If I am able to post a video I will when I get homeOh wait, you’re saying that the counter balance setting influences the ability of the auto cue to lift and place the tone arm correctly?
That sounds more like the cueing lifter needs to be adjusted. (No idea how to do this though!)
attaching images from Organ Donor Parts to help you identify them when you’re looking at it from underneath.
https://organdonorparts.com/Yamaha-YP-B4-Turntables_c186.htm
View attachment 2559023 View attachment 2559024
I'm not totally sure what in the lifting vertical movement would impede the arm from going horizontal. Like I said, big novice here. Also I should find a glass table and lay under it while it's playing!This is what the lifter post looks like in mine, there’s the retaining clip and the spring below the clip.
At the other end of the brass arm is the cam wheel attached to the cueing lifter.
I’m not sure what interactions with the end-of-side auto return and the Start cue button to induce lifting.
View attachment 2559380 View attachment 2559381
