Bill Huffman
Member
I've been looking for a deal on a good Yamaha TT to go with my CR-1020 that I'm restoring. I took a chance on a YP-D71 that was listed on the bay with a "bad motor" that made "grinding sounds" and needed to be replaced. It's in very nice condition but it is missing some items (headshell, anti-skate weight and arm/roller). Similar units that are from Japan with the same missing parts are listed at twice what I was able to buy this for. I did enough research to know that the only mechanical friction point that the motor has (or entire unit for that matter) is the motor main bushing. I expected that I could clean the old sticky oil out and re-lube it and I'd be in business. Well it came on Sunday and I cleaned and re-lubed the motor; still making noise (more popping then grinding to me). I took the bottom cover off and there was a 1000 uf capacitor that had leaked on the board and corroded the solder off of one of it's terminals. I replaced it and the one next to it with some old caps I just pulled out of my CR-1020 that appeared to be ok. I got lucky and the motor spun right up, tone arm dropped and I am in business. I put an aftermarket head shell on it to ensure she works. It tracks nicely with no anti skate. I plan to peel the vinyl off and veneer this and the CR-1020 case with tiger ebony veneer. I will re-cap the entire TT and make the anti-skate system. I may get a stock head shell but the only one found so far was $100... nope! Here some pics:
Anyone who has one; what cartridge are you using?
