Yammie part replacements
Detailman
Addicted to tweaking
Picked up a A1000 integrated along with couple Pioneers as a package.
Seller lied of course so I've got a little too much dough in the Yammie.
No output at speakers.
Found some outputs and pre drivers bad. I've been searching lots of sources but all I can really come up with are nte replacements.
Don't like to use them unless necessary.
Original parts are
2sa1306 pre drivers
2sc3298
2sa1333 complimentary outputs
2sc3370
Anyone with experience with this unit?
Or parts recomendations?
Thanks
Know it's not really vintage but looks to be well built.
I have had very good success and customer service with B&D. Just recently I received the wrong transistors and they sent me TO-220 mica insulators instead of TO-3P. They sent the proper stuff straight away and told me to keep the wrong parts. It should say a lot when I'm in Canada and I get a lot of my semi conductors from B&D in the US.
I appreciate the recommendation. I like to do business with trustworthy companies. I know the counterfeit business is large so I was concerned with that.
I do like the way their web site is set up. One of the easiest to cross-reference parts I have found.
Thanks for all the help.
Just a word of caution... I'm not just speaking in regards to B&D but in general, don't always trust or assume the cross provided as being suitable. You have to make sure its suitable for your application and I double check data sheets whenever possible.
Roger
Appreciate that. I did place an order and the crosses seemed to fit the specs well.
I must have checked 20 sites and after the recommendations here I liked B+D best.
Will follow up when finished.
I deal with B&D on a regular basis and have yet to be disappointed. They gho out of their way to get me subs when the originals are no longer available.
This is my first shot but must say pleased so far.
Already notified of shipment and should have delivery this week.
Thanks all.
More Words of Caution about Subs
Even if it is a direct replacement always CHECK THE PINOUTS!!!!!!!! I learned this the hard way on a Advent 300, it had damage when I got it and I replaced the transistors and when I turned it on it blew up again. After double checking all the pinouts and confirming how they should be hooked up in the service manual on the circuit board, one transistor had two legs swapped and was slammed on when I powered up the unit and took out 4 other transistors. ALWAYS CHECK THE PINOUTS IF IT IS NOT THE DIRECT REPLACEMENT!!!!! Although after my advent adventure I always check either way.
PS:I have dealt with Georgia Audio labs before. Very nice people and are more than happy to answer any questions or concerns. I almost always found them to be the cheapest for any output transistors unless I found them at Electronics Goldmine or someone similar. B&D seems good also but I have not bought from them yet (server seems down today, so I did not do price comparison).
