Butler
Hi Kenwood/Trio lovers,
Yes another KA-4002 restoration. Picked this up recently, ran it up first on a lamp limiter for a bit and seemed to be working fine for a couple of days and then, nooooooo, that dreaded distortion in one channel, I don't think it had been used in a long time and I was hoping I was going to be able to enjoy this for a while before I would have to get the lid off. Has had a bit of a dust. There is one thing that I haven't seen on any other pictures is this added PCB, with I presume power from pin 38 and then wires into the tape monitor switch and tape dubbing socket?? Anyway just some pictures to be getting on with.
Wooden case, needs a bit of attention.
Has had a bit of a dust and a cap count. Also noticed it has a cable with an earth fitted
You can see that some of the caps are a bit swollen on top so they will be my first port of call, full recap.
Wiring from additional PCB.
Have used @dlucy thread and BOM to from a parts list for the restore, most probably ordered more than I need but when there is a minimum spend to get free delivery, may as well, will always come in handed anyway.
2 Hours later and still good,
they look great.
spent almost a day measuring, pulling and testing transistors, caps and resistors. Re-flowed just about every track as well. Ends up being the Tape monitor switch. I squirt of servisol switch cleaner and a few in/outs all fine......... at the moment, whats next?
