sae-7125
after reviewing more than a few threads across the usual assortment of forums, and some one-on-one with a calculator, there are a few things that seem slightly disaster prone for the cj mv75a-1 (mv75/mv75a/mv75a-1 evolution family tree). i will refrain from boring readers with the parts cooker oven design theme...
for the 6550 bottle a calculation of 35w/anode voltage = 100% bias current setting per 6550.
for this cj amp running 590v anode the max bias would be 35/590 = 59.322ma per output tube. each output has its own bias adjust pot with an LED indicator operated by an LF353n dual op-amp which responds to 1.2v across a 20r 5w cathode resistor. so, 1.2v/20r = 60ma (per tube) which means the bias is running at or close to 100% since the owner/operator manual says to adjust up until light turns on and then slightly down until light is off.
what is the life expectancy of average 6550's regardless of brand/flavor vs bias setting? is there any noteworthy variance compared to the 6550eh (electro-harmonix) bottle?
many regulars of the tube side of hifi say 70% is close to ideal which would be 41.52ma or 830mv. when feeding the now repaired/updated amp 110v mains (still slow and cautious with testing) one output bottle is unable to min bias below 950mv so far. is it showing extreme signs of age/abuse from the factory bias inferno?
this particular make and multi rev model tube amp seems to have more than a few design negatives about it even though it was cj's first attempt at a tube amp albeit 2nd design rev.
small and blurry schematic slice
a few people have adjusted the amp to run kt88 and some mention kt90 being a nice robust upgrade but i have my doubts about how much "output wattage per channel" can be achieved when there is a 20r 5w cathode resistor involved. perhaps this is a 25-30w/ch amp that can do 75w of dynamic power at some questionably high percentage of distortion, jury's still out on that calculation.
thoughts, ideas, experiences or the occasional nixon themed quagmire? life experience results may vary.
Electro-Harmonix 6550 Power Tube | 6550EH | Electro-Harmonix
Electro-Harmonix tubes are all new designs and are of excellent quality. Many OEMs use relabeled Electro-Harmonix vacuum tubes in their amplifiers. If you want great sounding tubes at a very reasonable price, then Electro-Harmonix tubes should be on your l | 6550EH
shop.ehx.com
