Efver
Hello there. Been lurking around here for a while, finally pulled the trigger regards a rebuild and modding of my Au-999. I´ve had it for about five years; these units are somewhat rarer here in Sweden I believe.
I have never done a rebuild of this magnitude, and it all feels a bit overwhelming to tell you the truth!
I am a novice, so please be forgiving with me!
To make it a bit more comprehensible I´m planning to divide the rebuild into sections. Also, this is my only amp at the moment, so the time it will be up on the work bench could perhaps be kept at shorter streaks.
I have already begun with the removal of the subsonic filter. The unit is otherwise stock, apart from four new bindingposts.
My plan for the first section of this rebuild is to start with the the mods (ordering the correct parts for these mods) + ordering and changing the filter caps and bridge rectifier.
Thoughts?
______________
For filter caps Nichicon LKG 10000uf 63V
https://www.mouser.se/ProductDetail/Nichicon/LKG1J103MKN?qs=Ysb/BSeDKl3ywbTlpPp5NQ==
I´ve read recommendations for 12000uf 100V filter caps as well. Would the amp benefit from an "infinite" increase in filter cap capacitance and voltage?
___________
Bridge rectifier upgrade. Would this one be "appropriate"?:
https://www.mouser.se/ProductDetail...V2i03Pvz7eu30Uz9yLVjBMQ7vWr1tpa3oSGHnEttezA==
Greatful for any kind of help here! Thanks
Thoughts?
______________
___________
