ab0ez
AB0EZ
Ben,
1) I can't remember right off hand what size solid copper wire I used for the input RCA signal and ground leads. You are correct, I covered them in heat shrink due to their close proximity to other leads/wiring. That is the same wire I used for the ground buss.
2) For the heaters, the really important wires are the ones that go to the output tube filaments. The 6CG7 filaments will work nicely with 18 or 20 gauge wire, as the length of the runs are short. For general hookup wire, I use 20 or 22 gauge Teflon insulation silver plated stranded wire. I like Teflon because of the very high temperature tolerance and I like silver plated stranded wire for it's low resistance/impedance.
3) For caps, resistors, sockets, etc I shop around and get the best price from numerous vendors. One time a certain vendor has the best price, say on a lot of 100 resistors. Next time it will probably be another vendor. Sorry I can't be of more help on that issue.
Again, feel free to ask any and all questions. As my first supervisor in the Air Force said to me: "The only dumb question is the one you didn't ask!"
Jim, AB0EZ
Jim, AB0EZ
