thanks for the responses, I read 35ma "idle current", is this no volume? current increases with volume or tone boost.
thanks again
For me new JJ 7591 tubes seem to be happier at about 300mah (measured with a 10 ohm resistor) If I run JJ's at much more than that I see a bit of red plating after a while. I have not used EH at this point.
ok
they measure from outside to inside, .342,.325,.315,.301
the resistors were checked and measured 9.9 0hms ea. on a good fluke multimeter. Bias voltage is about -15v at 117v from variac.
these are new EH 7591s.
Is it normal for the voltage to drop this much from tube to tube?
I tested with fm on at low volume through ads L-520s.
seems bass heavy with everthing set flat.
That's what I'm running my JJ's at also, no red plating so far (~10hrs). Overall I'm pretty happy with them. I was a little concerned after all the negative comments I've heard, maybe their quality has improved a bit?For me new JJ 7591 tubes seem to be happier at about 300mah (measured with a 10 ohm resistor) If I run JJ's at much more than that I see a bit of red plating after a while. I have not used EH at this point.
So far so good.
What to measure? My 800c list the bias voltage is being -17v at pin 6 on the 7591 tubes. I was told to aim for -19 to-21 for better tube life. I have added the 10ohm resistors and have done the resistor and cap change as well.
Right now I have the fixed bias resistor, but plan to install a pot to make it adjustable. Should I focus on the voltage or the current across the 10 ohm resistors? Which is more crucial? Also if I want to add a test point for a meter to check this voltage, do I just check it on one tube's pin 6?
John
I have changed the grid resistors to 220k, coupling caps 0.1uf.
changed bias rectifier with a new bridge rect. and changed the 1000uf filter caps. Today I swapped in new diodes for the B+ and changed the 2 0.01caps. The B+ was 365v, and is now 390v, schematic shows 395v.
Highest tube now measures 36ma a little high but certainly not red plating. The filament voltage to the 12ax7s is also a little high at 24.68v.
these measurements are at 117v through a variac but I would like to eventually run straight line voltage. Line voltage in my shop is around
119v, but this is a single 20amp circuit on probably 100' of 12-2 uf(detached garage) and may vary according to how many lights etc... are on. I'm guessing house voltage is 122-124.
what cap and resistors can I use to drop the voltage to the 12ax7s,as I don't want to shorten the life of these tele's?
