birchoak
Hi-Fi Nut
For fun; anyone taking this thread too seriously will be forced to read all of the short stories I wrote in college or re-cap a Yamaha CR-800 with a pistol-grip soldering gun.
Ahem. We love our gear, don't we? Sadly, it doesn't always love us back and can be prickly to maintain over the long haul. So, rather than split hairs over the most powerful or best-sounding amp/receiver, how 'bout
1. Best-sounding (highly subjective! Let's not start a war over this one.)
2. Dead-reliable (within reason--ok if it needed to be recapped, had a new bridge rectifier installed, some transistors replaced, etc.).
3. Easy to maintain (by the Common Man, not an electrical engineer! Should not require extensive and expensive test gear--a DMM, a DBT, and some TLC should be the main tools required to tune up this sexy workhorse (oxymoron?).
From my modest hoard, I nominate the Sansui AU-555A:
1. No FM/AM boards to deal with.
2. Only 3 boards, two of which can be unplugged and worked on separately.
3. Cap-coupled, so no DC offset to worry about once you've replaced those output caps.
4. Rugged, solid aluminum knobs and face plate with engraved writing (holds up to cleaning without taking the lettering off).
5. Only one lamp to change.
6. Setting bias is very straightforward and center voltage can be gotten close enough with multimeter readings.
7. PRE/MAIN jumper pins vs. a switch = one less thing to go wrong (although they do need to be kept clean).
8. Well-known on AK as one very sweet-sounding amp.
9. The un-restored unit I have still plays rather nicely, without nothing replaced yet except the speaker fuses.
Chime in with your own examples! Argue with me about the 555A! But let's have fun, ok? Peace out.
