haven't seen that one specifically but the idea of introducing problems by messing with stuff that isn't having a problem is not lost on me. The more you pull and plug in tubes, the more those contact surfaces wear. I don't regularly pull my own stuff for checking. Mostly that is reserved for unknown tubes that I might want to put in something, or confirming a problem.
recent example, and why I know the test data for a 7199 is wrong on the Eico 667. I had a Dynaco ST-70 here for some work. Listening at low volumes it sounded fine. When I gave it the beans it started to sound noticeably funny. A quick voltage check turned up nothing obvious. On the scope I was getting significant asymmetrical clipping at well below the 30-ish watts I expect to see from one. Some further poking showed a normal sine output from the plate of the 7199 inverter and a much weaker one from the cathode of the inverter. After I figured out the setting problems on the tester, what it told me was there was very significant heater-cathode leakage on the triode side of the 7199. It was so bad that the cathode was effectively working into a much lower impedance load than it should have been, and the output was weak as a result. Different tubes fixed the problem and it performed like it should have.
if I'd just tested the tubes before I even bothered to turn the amp on it would have saved me some time.
