zinda
Member
Recently there's been lots of talk involving DSPs to put the cherry on top of a system so to speak. Using it mostly as I saw for subwoofers and room correction. I had an opportunity to get full use out if one of these so I figured why not?
My system uses a pre amp, dual 25 band eq (with spectrum display, pink noise and pure tone generator with single or sweep plus a microphone input to do testing - so I have something to check back to see where things are going), a 3 way active crossover, 3 separate 500w RMS 2 channel amps feeding 2 - 3 way DIY speakers. I figured I could take full control over the entire system and replace 2 components right away in the process opening up a large space too.
Fully understanding what they do and what the terms that they use to work with these things I saw it to not be an issue with setting it up quickly to get a starting point. Setting crossover points and assigning them to outputs, even putting a bit of eq in place mimicking what I had already found to work for me. Of course this all needs to be done using your computer so that means long rca cables, converting rca to mini headphone and back blah blah blah. After rounding cables and changing my stereo around I had a mess of rca cables that needed to be changed to 1/4" or XLR! So after another 6 hours of making cables I was ready to get started. At first I hear nothing, then check through the huge pile of wires and recheck which amps went to each output and tried again only to hear what sounded like it was bring sent through a tin can before the amps. Back to the computer. What a pain in the ass!
So if everything is set right what do I change to make it sound like I did a few hours ago? Well I couldn't get it to sound anything like it did so I figured I'd turn off everything and just let it run full range with no eq. Connected it and it still didn't sound right. Everything flat ran into my 3 way crossover and it was altering the sound beyond comprehension? Back to the computer checked every for defeat. Yup! Ok try something different using a mic to see if my changes are actually affecting what they show they should be. Nope.
2 more days of struggling to figure out why it's ruining my sound and I download a freeware program with rta fir the comp. Well the first thing they want me to do is test my computer to make sure it can even be used for this purpose. Funny but I wasn't told to do that with the DSP but it made full sense to do this in my mind. After a few tests I find out that my top of the line Realtech sound chip on my gaming motherboard has a high level of distortion on 1 channel as it passes sound through the mapper and back into the card. Next was to find out if it is on the output or input. At this point I didn't even care. I tried to see if it could be masked and no, my computer was unable to work properly with audio? Funny how the DSP had no concern to tell me that I should be running tests first, but that still didn't explain why the sound was bad even running it by itself?
So after 3 days with nothing to show but a pile of cords that I wasted time making it went back. S few months later I see ==er DSP that I can use all features and this one could be set without a computer since it has a read out onboard and Bluetooth with an app for the phone. This time I was able to use regular cables running to a strip connection which made it way easier to set up since I was already using that input I was ready to go quickly. Once again the set up was straight forward and I did a quick crossover set up or do I thought it would be. The 3rd channel would not accept the new setting at the low end. I tried 10 times and finally skipped it and did the 4th 5th and 6th. Than returned to 3 and after 8 more tried it moved closer but still not where I put it. I turned it off and on then tried a few more times and I was able to set it but then had difficulty changing the slope. Eventually it changed and I was ready to plug the amps I to it.all volumes and input levels are zero and turned on the pre and started music. My outboard eq that was disengaged from the I put showed sound.
I turn up the input on the high amp and it sounded weird but I figured it's just playing the tweeters and very low volume . I turn on the mid amp with inputs down at zero I start to turn both dials and I hear this ripping noise coming through the mids on one side or both I turned everything off by pulling the power on the DSP.
Checked all settings and connections same thing. Set everything flat, connected another amp I wasn't using and a set of full range speakers up to channel 1 and 2, it worked but it sounded like it was playing through another tin can!
At that moment I decided that I wasted enough time with these worthless items and promptly packed it up to send back the first was a miniDSP the 2nd was an Expert connect p2. Without even considering anything else but the AD-DA working at only 24 bit I can't see these things being worth the time to even consider. The expert also gave a loud pop when I adjusted the low crossover point that send sound though every driver at full power. If I was using any other type of tweeter than electrostats they would have been killed.
I read these stories of these huge improvements using these but I have to wonder how terrible did their system sound prior to that? I changed mine back and was able to get it within reason in 15 minutes using 40 year old equipment that is dead silent and 100 percent analog! Simple turn of a dial or slider while watching the display and that was it! Has anyone ever really used these with any real success?
